Old 10-24-2023, 04:13 AM   #7
PLP
PLP's Avatar
My honest opinion? I would not say professional, but a decent opinion.
None of the LED plug and play is any good.
I had done enough research and testing to realise it is never going to be good.
Think of it for a moment.
The reflector bowl (projector or reflector - all work same) is a specially designed mirror. It uses a halogen filament as the light source. The light source is very concentrated.
Look on your H7 halogen. The filament is tiny.
Now, take any of the LEDs and compare them side by side.
You will notice LED chip is often small as the filament, although there are some what are much bigger. Then, the biggest difference is the light visibility. It means the chips are on two sides of the metal plate. It is due to the fact the LED chips emit light at about 120 degree angle. So they put 2 of them that would cover a total of 240 degrees. Still 120 degrees are missing...
What does that mean?
Well, first of all - the reflector mirror will not see enough light where it is expecting it. You will have tow sides of the LED chip assembly with no light: two 60 degree-wide patches.
Then the concentration of the light is not the same as in halogen. The LED chip will be different size. Plus you add some metal that sticks out in the light path...
In the end the beam pattern is affected. Sometimes more, sometimes less.
If you got here, look on my older testing using projector headlights which are less prone to those distortions, but still suck with LED chips.
And it does not matter if you get a 50 USD eBay China kit, or 350 USD TRS, still China made, kit.
This one talks about LED vs HID vs Halogen. good read, yes, self promotion, but the point is output performance.
https://www.forteturbo.org/threads/hid-or-led-debate-comparison-morimoto-4300-k-hid-and-2stroke-led-from-trs.2937/
Same thing on another forum.
https://www.fiat500usaforum.com/forum/fiat-500x-forums/fiat-500x-upgrades-and-diy/23764-led-or-hid-or-oem-halogen-comparison-review-9012-morimoto-led-2stroke?27223-LED-or-HID-or-OEM-halogen-Comparison-review-9012-Morimoto-LED-2Stroke=
This is what you actually want, but it is a PITA to perform, unless you pay someone.
I am planning of doing it, if I decide to keep Boxster for a long time.
https://www.theretrofitsource.com/bi-led-morimoto-m-led-2-headlight-projectors-P-M-LED2?quantity=1
Current rides: 2003 Porsche Boxster MT (me), 2019 Bolt LT (me), 2015 Audi Q5 (wife), 2008 VW Rabbit (2.5 inline 5, MT, well, for kid... but you now, it is the 5 straight)
Previous: 2014 Fiat 500e, 2016 KIA Forte5 SX, 2016 Fiat 500X, and some old days: Trabant, Fiat 126p...
PLP is offline   Reply With Quote
