Old 10-23-2023, 12:30 PM   #8
elgyqc
elgyqc's Avatar
I bought the new piston and spring, but did not use them in the 3.2 replacement engine that I was installing in my S. Instead I did as mentioned above, ground a chamfer into the old piston and placed 2 washers under the spring to increase tension. With that my oil pressure is a bit low on my after market oil pressure gauge, which I am sure is reporting the pressure a bit lower than it really is (oil pressure light never flickers). I replaced my reworked piston and the old spring/washers with the new piston and spring. After an initial test it would seem that the pressure at idle has increased a bit, but I will keep checking it.
Grant
