Old 10-20-2023, 05:47 PM   #6
dghii
ignition switch (electrical section) is the biggest bang for the buck. Under $20, not hard to do and will keep you from chasing weird crap down the road.
Do engine mount when you do water pump. Makes the WP install easy. Do thermostat at same time.
As long as you're not weight conscience, when you replace your battery, get the H8 for cars with Tip transmissions. It fits just fine and gives you additional CCA.
Do spark plug tubes and O-rings. May help with oil weeping.
