Old 10-20-2023, 01:33 PM   #5
Gilles
Since you mentioned a rear wheel bearing I would replace the other ones as well (just as many miles as the one that has failed, so the others are not far behind..) it is a pain to do it but once it's done you can forget about them for a several years.
A good time to do it is when you replace the suspension components as everything will have to be removed anyway..
Good luck with your project!
