Old 10-14-2023, 06:31 AM   #1
robucop
I don't see any replies so, bit late but here's my two cents. these usually don't go wrong, most likely its the little bulb behind it that failed. you can check if the panel is still working by shining a light on it from the front (with ignition on). you should be able to see the clock or oil gauge working. changing the bulb it pretty easy, lots of info here, on youtube or google.
robucop is offline   Reply With Quote
