Old 10-11-2023, 01:39 PM   #1
elgyqc
elgyqc's Avatar
2000 Boxster 2.7l 5 speed.
I have updated this ad since it was first posted in late 2023
2000 Porsche Boxster 5-speed manual 95700 miles (154000KM). Colour is metallic green, the paint is original and has the normal wear and tear for its age. The clear coat is worn through in a small area on the left front fender.
The maintenance is up to date and almost everything that needs attention has been replaced, renewed or repaired .
Runs very well.
Carfax available, the car is originally from Florida but has been in Canada since 2004.
Full tool kit
I installed an oil pressure gauge
Partial list of work done.
Transmission fluid changed (Redline brand)
New gas filter, air filter and cabin filter
New rear brake pads and checked rotors
Front and parking brakes have been checked all is good
Brake and clutch hydraulic fluid changed
New serpentine belt
New coolant reservoir- Coolant changed
Cleaned drains for the top.
New front and rear trunk struts
Checked belt idlers, AC compressor, alternator
CV boots changed on the half-shafts, new grease
All four wheel bearings changed
Four wheels aligned in 2022
New seat skins
New Cooper tires.
New rear window in top
New battery
Two keys. The original remotely locks and unlocks the doors and rear trunk. The second one opens the doors and starts the car manually.
A list of all maintenance done, with dates, is available
The cam chain tensioner pads changed.
IMS bearing changed. Oil pressure spring and piston updated.
Inspected water pump. Checked belt idlers, AC compressor, alternator
New clutch plate. Flywheel inspected and pressure plate inspected. New pilot bearing installed.
New AOS (air oil separator)
500KM since oil and filter change.
Problems
airbag light on - new module needed
air conditioning needs refill or repair
Dent under the passenger side door.
$12,000 US
Located near Montreal, Quebec, Canada.
Grant
