Old 10-09-2023, 02:23 PM   #3
JBauer
JBauer's Avatar
If I am understanding your post correctly your turn signal bulbs light up they just don't blink when you use the turn signal stalk.
So I would check or replace the turn signal flasher... it is possible you burned it out when you shorted the circuit.
Front and rear turn signals don't light up with the turn signal stalk or the dash indicators. Turn on the emergency flashers and all turn lights flash plus the dash indicators also. The bright light switch on the stalk works as it should also. Everything works except all the turn signals with the stalk and the fuse is good. All started after a blown turn signal fuse from putting In an old set of headlight and blowing the fuse because of bare insulation on turn signal bulb.
