Old 10-09-2023, 09:18 AM   #2
blue62
Trying out some old headlights to see what I've got and put one in before checking the wiring on the turn signal bulb. Ended up it was frayed and blew the B2 turn signal fuse. I replaced it and now my turn signals don't work on any set I have. No turn indicator on the dash no turn signals front or rear. All other lights work fine and the odd things is the emergency flashers work like the should. Dash indicator lights, fine, front and rear turn lights flash fine. To me it looks like the turn signal stalk switch must of went bad. Am I missing something? Rechecked the fuse and it's good, just no signals with the switch. Anyone been down this road, ideas?
Thanks in advance.
If I am understanding your post correctly your turn signal bulbs light up they just don't blink when you use the turn signal stalk.
So I would check or replace the turn signal flasher... it is possible you burned it out when you shorted the circuit.
blue62 is offline   Reply With Quote
