Old 10-08-2023, 02:05 PM   #6
Nickanator8
Nickanator8's Avatar
I tried swapping the tires but the person who put my on drivers side wheel WAY over torqued the lugs and I can't get them off, even with power tools.
I'm starting to think the issue is not the wheel, nor the suspension. The wheel was just rebalanced yet the problem persists. I don't think it's the suspension because even on brand new pavement I still hear the noise.
I'm thinking it's got to be a component that rotates while the car is moving. I'm not sure if it's warped rotors as there is no vibration in the brake pedal.
I haven't completely ruled out a wheel bearing because although the wiggle test is negative the swerving back and forth test is positive.
I also jacked it up and put it into drive to see if I could get the noise to present itself while the car was stationary, but I started hearing other strange noises so I stopped immediately.
I'm kind of at a loss here. Any other thoughts before I take it to a mechanic?
Cliffy, 2000 Porsche Boxster S Tiptronic - The Sportscar Utility Vehicle
Nickanator8 is offline   Reply With Quote
