Thread: Lowered 986
Old 10-06-2023, 07:19 AM   #1
The Radium King
The Radium King's Avatar
are you sure it is camber that is destroying your tires? is the wear just on the inside of the tire, or all the way across?
camber should be relatively static with height change. it might go a bit more negative as you lower - strut at slight angle will pull top of wheel carrier in as you lower which will create negative camber and wear inside of tires. coffin arm as it rotates upward when lowering will will push bottom of wheel carrier out and create more negative camber which will wear inside of tires. but go low enough and coffin arms pass horizontal and start to pull bottom of wheel carrier in and reduce negative camber.
most people want more negative camber for better performance.
then there is toe. as you lower, oem toe control arms - which are not adjustable - will cause toe to go out of spec which will scrub your rear tires. standard practice is to get adjustable rear toe control arms so that toe can be put back in spec on a lowered car.
i'd be you money that your problem is toe and not camber.
