Thread: Coolant leak!
Old 09-30-2023, 04:58 PM   #5
LoneWolfGal
LoneWolfGal's Avatar
Originally Posted by HEC2907 View Post
I was driving home from work this evening and started hearing a graunching noise and then the coolant light started flashing. As I was determined to get home and the temperature gauge was reading fine I decided to drive the remaining 10 miles home. When I parked up on my drive fluid started streaming out from in front of the rear left wheel. The boot seems to be dry so I have a feeling that the water pump may have gone.
Has anyone else experienced this?
My 986 had almost identical symptoms. It was the water pump. I replaced the pump and thermostat and had no more leaking -- until the heater core started leaking. When I replaced the heater core I examined all the hoses to forestall additional leaks. So far, so good.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
