Old 09-25-2023, 01:46 PM   #6685
wiebuschk
I finally got some suspension work done. I knew I had a loose front ball joint, sway bar link and tie rod end. Also had a lot of clunk from the rear. You can help find the bad parts by hitting things with a dead blow hammer while the car is off the ground.
So in went new front control arms, Links and tie rod end. I replaced the rear tracking arms. The difference is amazing. Even my passenger (wife) mentioned how good the car felt. I consider this a win!
wiebuschk is offline   Reply With Quote
