Old 09-15-2023, 09:13 AM   #3
JFP in PA
As the Vario Cam system is controlled by the DME, which you say has an unknown aftermarket reflash, there is absolutely no way of knowing what is causing the issue. If you really want to know, reflash it back to stock, re-dyno the car and see where you are, that is the only way you will know for sure.
