Old 09-14-2023, 04:06 PM   #4
KevinH1990
KevinH1990's Avatar
Nice work. I replaced the headliner on my Mercedes and I appreciate what you accomplished. https://mbworld.org/forums/c-class-w203/787955-w203-headliner-removal.html
Your experience tracked closely with mine. I visited two upholstery shops and based on the high prices they quoted I thought a DIY effort made sense. The only point where our experience diverged concerns removing the residue on the headliner board. I found it puzzling that removing the glue was such a challenge. I used a hard bristle brush (which I ruined in the process.) It was unpleasant, but if I recall correctly it seemed to only require 2 or 3 hours. I recommend that anyone who needs to follow in your footsteps try the brush before attempting to use solvents. It is possible that Porsche uses a stronger/more difficult to remove adhesive than Mercedes and that you had a more difficult task.
Again, good work and thanks for sharing your experience. I have a Boxster, but I may purchase a Cayman someday and having access to this information may be handy.
