Old 09-10-2023, 11:38 AM   #29
Gilles
Since you will be replacing the oil filler tube, I would suggest to replace the accordion hose that goes from the bottom of the AOS to the top of the engine (driver side) as these plastic hoses are 20+ years old and get very brittle with age and heat.
To replace this hose you don't have to remove the intake plenum, as you can get to it from the engine cover behind the driver seat.
Gilles is offline   Reply With Quote
