Old 09-10-2023, 05:25 AM   #11
blue62
Originally Posted by jaimster View Post
how could I missed it - it was there right under my eyes !!!
the oil filler tube connection under the firewall through the trunk - DID another smoke test after reinstalling the oil dipstick tube ( may or may not have been the culprit after all ) .
oil filler connection broken leaking real bad - just order one from ebay I m pretty sure that has been one of tghe biggest ISSUE all this time NOT the only one thought
vacuum system was all broken all good now ..
thank you very much specially to BLUE62
Sounds like your starting to get things sorted out.
Vacuum leaks can be pain to track down on these cars.
Everything is under vacuum including the crankcase which is usually under slight pressure on most engines.
When you get the oil fill tube replaced let us know if that fixes the problems.
