Old 09-08-2023, 02:43 PM   #1
Danimal
Parts needed for OBC hack - 2001 Boxster S
I am interested in activating the OBC in my 2001 Boxster S. I have cruise control already, but I am missing the 4th stalk for OBC. Is it as simple as installing the 4th stalk and activating the OBC with a durametric?
I found a used combination switch with the 4 stalks, but is says it "Will ONLY fit cruise control / onboard computer equipped models with the 4 lever combination switch assembly." Should I just ignore their warning?
Also, does my car have the OBC function built in? There isn't a lot of room under the center gauge. Thanks!
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is offline   Reply With Quote
