Old 09-08-2023, 06:23 AM   #10
elgyqc
elgyqc's Avatar
Originally Posted by Nickanator8 View Post
I've seen this one and it is my front-runner of "fix it up" options. Here is the list of things that I took note of when I took a look.
Creaking suspension
Strange noise on startup
Both side mirror motors do not work
The windshield is cracked and needs replacing
One of the headlight sprayers is missing
The convertible motor is slow and sounds tired. May need replacing soon
The front bumper seems misaligned
The plastic undertray on the front bumper is partially disconnected and scrapes on the ground occasionally, particularly when reversing
The rear bumper is cracked
The driver's seat is torn and needs repair or replacing
The clear coat is peeling, there are hail dents and lots of scratches and scrapes. Just about every panel has some kind of damage
The battery was disconnected when we arrived, no idea what that means
Bottle of antifreeze in the trunk
The plastic trim by the windshield has hail damage and needs replacing
The clear coat is peeling on all four wheels
All of the Porsche crest center caps are damaged in some way
Most of the lug nuts are rusty
Rubber gaskets around headlights look dry-rotted
Two tire brands: Michelin Pilot Sport All Season and Cooper RS3-G1, all from 2021
And I'm probably missing other stuff.
When I drove it the car seemed fine, but I remember either the gas or brake had a lot of dead space at the beginning. It shifted through all the gears fine and seemed to drive well. I neglected to test the wipers and turn signals, and probably a few other things. There are no reliable records of any kind of service done. Also, the seat was a massive pain to adjust.
With the exception of the strange startup noise and windshield, these mostly sound like things I could theoretically take care of myself or just live with. Safelight will install a new windshield for $520, but the strange startup noise is what is giving me pause. It could be nothing, or it could be a serious concern. The bodywork makes it a 20-foot car at best and it's probably more money to get all of that repaired than the car would be worth with half the miles.
Honestly, this is the car that I'm debating making an offer on, I'm just not sure what kind of an offer would make it worth all of the known and unknown work. Beyond that, it just seems like a lot of little things and even though I feel like I've done a decent job of searching for all the replacement parts I would need from eBay, I'm sure I'm forgetting things, and the dollar signs are quickly adding up.
I already own the book "101 Projects for Your Porsche Boxster" and between that, the Youtube channel "Help Me DIY", and this forum it's giving me confidence that any problem I might encounter I will at least have a guide to get me through, but this would still be my first project car and it's intimidating.
I'd like to think that I'm reasonably mechanically minded, but I lack experience doing anything beyond oil changes, air filters, and swapping between winter and summer tires. I'd love to believe that I can tackle anything that gets thrown at me, but I also want to be realistic with my abilities. Tutorials are one thing, but they are no substitution for experience.
So yeah, hope that wall of text didn't put you to sleep, lol.
That is quite a list! On the positive side they are things that are relatively simple to fix. And you can drive and enjoy the car while fixing it, with help from the forums and youtube.
Normally I am not put off by things that are purely appearance, but even I am struck by all the esthetic issues, that is not work that I enjoy... and I am not very good at it... but that's just me.
If you intend to do your own work you need tools and a place to work, most of the things on your list can be done in a driveway. Anything more complex may need a garage, do you have one or access to one for short (or medium or long, depending) periods of time? Include some money in your budget for tools beyond the standard ones or see if you can beg, borrow, rent or steal them locally. I have accumulated a lot tools.
Too bad you are so far away, I have decided to sell my 2000 base Boxster which I have done a lot of work on and which has the maintenance up to date. It is the first Boxster that I bought, as mentioned in my first post.
Grant
