Old 09-06-2023, 09:34 PM   #1
Danimal
Reverse Rake after Corner Balance Normal?
After getting my PSS9s installed, I had the car aligned and corner balanced. I asked them to start around ROW M030 height and go from there.
When they were done the car seemed a little low in the rear, but it was hard to tell without measuring. After a couple test drives, I measured the ride height front and rear (based on the locations in the service manual) and got about 125mm in the front and 107mm in the back (minor variation side to side). So it has a reverse rake. However, the corner balance numbers look good (cross numbers anyway).
LF: 763/24% RF: 728/23%
LR: 861/27% RR: 827/26%
I'm not sure what they were measuring, but they listed the ride heights as:
LF: 25.625 RF: 25.625
LR: 25.125 RR: 25.375
Does this seem right? I was really hoping for 125-130mm in the front and 130-135mm in the rear. I'm not sure I can live with 107mm in the rear without bottoming out.
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is offline   Reply With Quote
