Old 09-06-2023, 03:43 PM   #5
jaimster
A few things that could cause your issue........
Bad MAF or MAF wires...and or connections.
Leaking Fuel Injectors.
Bad seal on the Oil Fill Tube Cap
Bad Fuel pressure regulator
Bad Evap Purge Valve under the intake manifold
Exhaust leak ahead of the Pre Cat 02 sensor.
right on Blue62!
I have tested the FPR good - after removing the vacuum hose pressure went up t0 60 PSI
have not replaced seal on Oil fill tube cap - did not see any smoke coming out of there on my last SMOKE TEST ..
how to test Evap purge valve ?
had the car running for almost half hour now TOO hot for smoke test - SMOKE TEST TOMORROW with engine COLD should be smoke coming out of the exhaust if there is a leak !!
so this is what I observed today after car warm up "
MAF a/c off 3.25 a/c on 4.0 g/s
while car was running disconnected MAF sensor SOMEBODY HELP ME UNDERSTAND THIS
after disconnecting MAF car hesitated a bit almost not noticeable CAR KEPT RUNNING
numbers on old BOSH sensor are 0280 218 055 986.606.125.01
0280 218 055 986.606.125.02 on new BOSH sensor only difference last 2 numbers 02
jaimster is online now   Reply With Quote
