Old 09-06-2023, 11:55 AM   #16
jaimster
Reading about the air filter hose and swapping different MAFs in makes me wonder if the wire harness or connector for the MAF is damaged.
Any potential air leaks between the MAF and throttle body?
Also if you search for the P1130 you will find some threads where it was a problem with the evap purge valve: https://986forum.com/forums/boxster-general-discussions/67910-fault-code-p1130.html
Also check again for more vacuum leaks - Brake booster vacuum hose, oil cap and fuel cap, hoses connected to the AOS.
MAF's connectors wires bad ! I would think it would truly affect it and run rough ?
I have an audio stethoscopes planning to use it maybe I can hear any leaks and another smoke TEST on the plans .
will check those other items too .. fuel cap too
I had also read the tread on "evap purge valve " disconnect it and blow on it
the car has 7 emissions components ready completed - wouldn't this keep it from completing if there was an issue with the EVAP PURGE VALVE ???
should have a chance later today .. will report on it
jaimster is offline   Reply With Quote
