Old 09-06-2023, 08:57 AM   #3
obthomas
Keep searching the forums. There are some alternatives.
A key at the dealership is expensive.
1. If only your buttons are not working you can buy a switch repair kit and do some micro soldering of new switches inside the key .
2. You can buy a cheap keyless entry kit from ebay and follow forum instructions to substitute it into the car and work it into a keyless fob plus your key to get all the original features.
3. You can remove the pill from your key and afix it next to the ignition switch and any key cut for the switch will work to start the engine.
A combination of 2 and 3 get you out of the Porsche handcuffs
Good Luck
obthomas is online now   Reply With Quote
