Old 09-03-2023, 10:07 AM   #17
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by BFeller View Post
Your use of foaming upholstery cleaner on engine is nee. The results look great.
Thanks. I should add greater emphasis to using LOW Pressure if using a power washer and pay attention to where it is pointed. The wire harness connections were water resistant 20 years ago, but may not withstand direct pressurized after. I like to run the engine and warm it up afterward to help clear off residual moisture and make sure everything is good.
