Old 09-01-2023, 09:52 AM   #2
elgyqc
elgyqc's Avatar
I had a more or less similar problem caused by broken solder connections on the PCB inside the latch. It could be that moving the wire moves the connector pin on the latch causing the broken solder connection to make contact. If that is your problem the fix is indicated in post #13 in this thread:
Door window not dropping properly – a troubleshooting check list.
Good luck.
Grant
