Old 08-30-2023, 11:25 AM   #2
Makrilli
Have you tried to manually activate the microswitch near the rear view mirror?
I had the same problem and I had to heat the arm that activates that microswitch and twist it slightly to make it work like it should.
Temporary solution for me was to stick couple layers of duct tape on the top latch so it pushed the arm further into the microswitch.
Edit: the arm I mentioned is a small plastic part inside the housing near the rear view mirror, not the top latch.
Makrilli is offline   Reply With Quote
