Old 08-26-2023, 11:06 AM   #10
jaimster
great .
I actually ended up removing the intake wanted to get a better view on things !!
found all the small vacuum hoses broken from reservoir, change over valve, injection check valve a mess all over pretty much .. lol
also, found some hoses at Oreilly's small plastic hose and large one I m thinking of using it fits great into the " Y" connections.
list of parts to getting :
long AOS vacuum hose to PVC found broken connection or NOT sure if I broke it ! anyways Im buying a new long hose found it at AutohauzAZ.com for 32.00
. Intake gaskets (3) 23.00
.check valve 15.00
parts from europarts.com change over valve 28.00
fuel injector lower O rings $ 3.0 or SHOULD I GET THE KITS ??
SHOULD I GET THESE PARTS ??: vacuum reservoir 21.00 , air injection check valve 135.00 these parts are right there underneath next to each other...
your thoughts ??
jaimster is offline   Reply With Quote
