Old 08-26-2023, 03:43 AM   #7
tcoradeschi
Registered Member
Originally Posted by Danimal View Post
I searched around, but didn’t find too much info. What are everyone’s thoughts on rear subframe braces, like the Technobrace or adjustable rennline?
Would stiffening the rear chassis help reduce understeer? My understanding is that softening the front and stiffening the rear helps reduce understeer. Or would only a sway bar help with that?
Thanks!
Given that these are bolt on parts, you can always bolt them on later. I think that you will find that the limiting factor to how your Boxster performs will be the performance of the nut behind the steering wheel. I’d suggest that you spend your money on DE, not on trinkets.
Tom Coradeschi
03 Boxster
tcoradeschi is offline   Reply With Quote
