Old 08-24-2023, 05:11 PM   #1
jaimster
do you know if these 2 items :
SAI: Vacuum source -> electric change-over valve (E) -> change-over valve (D).
are located next to the vacuum reservoir ? I'm debating whether I should pull the
intake to get to it ( hate to mess with these intakes) although maybe I should change the gaskets on both sides too
I can't get to these items if they are underneath the intake which most likely they are !! unless the vacuum intake is removed
jaimster is offline   Reply With Quote
