Old 11-12-2006, 05:05 AM   #4
edevlin
edevlin's Avatar
Adventures with Exhaust
"Anyway, I think you are right. Header that I got from Che has a bung on the end of header. So I will install the front sensor like you recommended and I will plan to install O2 sensor with O2 sensor eliminator at the rear of 100cel CAT. By the way what kind of wires did you use to extend the wire to the back side of the engne? Do you know where to find temperature rated wire? Or you know where I can find extension wire for Bosch O2 sensor? Please advise. Thanks. PS. Good luck on your experiment. I hope that works."
We used wire from old O2 sensors to extend the wire. BTW, if you are extending the wires, be careful that you match up the wires properly. They did not seem to be marked that well. I think two of them were marked the same, I suspect they were just heater wires. When you get a CEL after an mod like this, we end up second-guessing what may have gone wrong. If you get the wiring right, that will eliminate one of the variables, have fun,
Ed
My Car Webpage
2000 2.7L Boxster 102K; TTP intake, headers, high-flow cats; Dansk high-flow muffler; Autothority ECU chip; TechnoTorque 2; Bilstein coilovers; Racing Dynamics strut brace; stress-bar suspension kit; Aasco lightweight flywheel, B&M short shiftkit; 18" wheels; spare tire delete; OEM GT3 seats; JL audio speakers and subwoofer; Alpine PDX-5/PDX-2 amps; Kenwood DNX8120 CD/DVD/Nav; litronics, deambered
edevlin is offline   Reply With Quote
