Old 08-22-2023, 03:25 PM   #4
Gilles
Originally Posted by Danimal View Post
My thought was to stiffen the rear with a subframe brace and not mess with sway bars for now. Perhaps thats wishful thinking
I believe that the rear brace is to stiffen the rear suspension (to help maintain the alignment settings while under load, specially when using sticky tires)
To adjust the over/under steering you need adjustable sway bars, but you also can start experimenting with the tire pressures on the front and rear axles as well to help reduce the understeering..
