Old 08-22-2023, 05:49 AM   #13
redpepperracing
redpepperracing's Avatar
Originally Posted by soundguy View Post
Removed the instrument panel today. All the connections look good and appear to be solid. No broken wires I can see. As long as I had the whole thing apart, I replaced nearly all the bulbs. Went back together easily enough, but still have the original problem- no backlights on the Tach, speedo, temp/fuel gauges. So driving at night can't see any of that. The small lights within each of those are working ( high beams, turn signals, etc )
Any ideas what to try next? Thanks.
The bulbs for the tach, speedo and temp/fuel gauges are different from the other bulbs, did you replace them with the green based ones or black? I mistakenly used the black ones and they didn't work, once I put in the green ones they worked.
Something to try, anyway.
redpepperracing is offline   Reply With Quote
