Old 08-21-2023, 08:08 AM   #7
Luckyman01
I am confident that I am NOT hearing the fuel pump unless I jump the pump relay. I did replace that relay. Also the two related relays back in the trunk.
I have a full tank of gas which will a PIA if it is the fuel pump.
I did replace the CPS.
As the car will run with the fuel relay jumped, the same method to empty the fuel tank.
I did replace the fuel tank sender last winter, did not change the pump itself at that time.
I have reviewed what is on the forum, however I will find yours Starter986.
Thanks for taking an interest.
David
Luckyman01 is offline   Reply With Quote
