Thread: Oil leaks
Old 08-19-2023, 12:07 AM   #13
DShen
Okay so I started the car for about 2 mins to warm up the oil. Got under and saw the leak in the photo attached. I then changed the spark plug tubes (they were definitely also leaking) and plugs, and did an oil change. Very very tiny bits of metal on the magnetic drain plug. I checked the oil filter and it was super clean, just oil. So that rules out IMS leak?
My guess is RMS leak. As stated the last time the rms/ims/clutch was changed was 40k miles/9 years ago.
I'll inspect the engine from the top to see if there are leaks from up there. What do you guys think? RMS for sure?
DShen is online now   Reply With Quote
