Old 08-17-2023, 08:31 AM   #13
JFP in PA
Originally Posted by Jerry238 View Post
Hi, Well I took my reader Icarsoft Porsche compatible back out this morning after watching some youtube videos. When I just read obd codes there are none. If I go into Diagnostics and manually choose AirBag system and then get codes it gives me a 0003 code and says below it power supply. Does that help to diagnose it. I live 3 hours from a dealer and 2 from a good indie shop. I don't have a manual or wiring diagram. All i did was move the seat forward to gain access to change water pump. What a headache. Thanks, Jerry
That code, 0003, indicates a low signal from the fuel volume regulator. So unless you have a system wide electrical issue, it isn't related to your air bag issue.
That said, if the air bag light is on, there must be an attendant code, which your scanner is incapable of reading. You need access to a real Porsche specific tool like the Durametric system, a PST II, or a PIWIS to really see what is going on.
