Old 08-15-2023, 11:36 AM   #3
JFP in PA
Originally Posted by jaimster View Post
so I have been getting these codes off and on after messing a while back with intake and throttle hoses .
I just replaced a starter , cold air intake system by BB performance , new maf sensor OEM
sepertine belt - car runs so much better however still getting these PIA codes
even did a smoke test few weeks ago before I did that work .
question : how can I isolate the issue more precisely ?
should I get the DURAMETRIC CABLE to be able to monitor what is going with fuel trims , o2 sensors , throttle body and son on ????
will that get me closer to what is going ??
Both codes indicate that your intake charge is so rich that the DME cannot adjust for it.
Possible causes:
  • Incorrrect MAF siganl
  • Fuel pressure too high
  • Leaking injectors
  • EVAP canister purge valve stuck open
