Old 08-11-2023, 02:17 PM   #1
somerled
Could battery reading 12.2 volts cause starting issues?
Recently bought an original '98 Boxster which seems to have intermittent starting issues. Sometimes it starts fine and sometimes nothing happens on the second stage of the key - no ignition, crank, starter. A few more attempts and it eventually does start. All dash lights always come on.
I used a multimeter on the Yuasa battery with the engine off and it reads between 12.2 and 12.3 volts.. and sometimes the multimeter doesn't get a reading at all and shows 0.0. The indicator 'eye' showed black initially and then green once removed and moved about a bit.
Apparently the battery is quite recent (or so I was told) but the car had been sitting for around 2 years until I bought it and I doubt it's been replaced since then.
Could this voltage cause these issues? I'm really hoping it's not the ECU. Carpets feel every so slightly damp but I have no other electrical issues (alarm, windows, radio, central locking all work fine...)
Thank you.
somerled is offline   Reply With Quote
