Thread: Driving temp
Old 08-11-2023, 08:47 AM   #1
elgyqc
elgyqc's Avatar
Originally Posted by wiebuschk View Post
My 99 model Boxster base is running at 210F according to my scan tool. Honestly my dash gauge is pretty accurate surprisingly This is right around where the high speed fans come on and the thermostat is wide open. It is hot here being 95 to 100 degrees. I have no idea the age of my thermostat or water pump. I plan on changing them out when I get the nerve to break off bolts. Do yours run this temp in these conditions?
It doesn't get that hot here, so my experience at those temperatures is limited. Two things to check 1) are you low speed fans working? On my 2000 S neither fan works at low speed, replacing the resistors is at the top of my list.
2) have the radiators been cleaned recently, all sorts of stuff collects in there and cuts down on air flow.
Both of these operations are simpler than changing a water pump and can be done at the same time with the front bumper cover off.
I am in the process of preparing new DIY resistors like in this thread, see post #25.
https://rennlist.com/forums/996-forum/737811-ballast-resistor-replacement-2.html
Grant
elgyqc is offline   Reply With Quote
