Old 08-09-2023, 11:37 AM   #18
Gilles
Originally Posted by elgyqc View Post
I have used mine both ways, lately I have done it the opposite to you (front of the car moves forward) because I had to use my engine hoist to lift the rear of the car to get the engine out from underneath, and it is less likely to tip forward with the installation that way. I have changed a few things and now don't need to raise the rear of the car so it doesn't matter anymore.
I have not used the quick jack enough times yet, but always wander if the balance of the car would be upset (and fell off..) if I tried to raise the car one end of the car while the car is up on the quick jack.
The reason I am asking this is because I built a set of wooden crates that I use to put the car up with the weight on the tires to perform the alignment, and the process is a bit tedious since my car it's pretty lowered and require to use the floor jack several times to put the car on top of the crates, somewhere.
But if the rear, or the front axle, can be raised more (off the quick jack..) with the floor jack it should make the procedure way quicker, but was afraid of the car falling and getting damaged.
PS: I have a picture of the car on top of the wooden crates if someone wants to see it.
