Old 08-07-2023, 11:58 AM   #10
spdrcr21
Thank you all for your suggestions. I did charge the battery (and tried jump starting the car with another running car) and the car still will not even crank. When I attempt to crank the car the tach gauge doesn't even move (which I thought might indicate a bad CPS, which I've replaced. The next steps are to to a voltage drop test on the starting system. I might as well pull the starter since to test the full system I'll need to access the connections on the starter. Anything else I might look at before I start testing the starter?
spdrcr21 is offline   Reply With Quote
