Old 08-07-2023, 07:39 AM   #16
redpepperracing
Somewhat unrelated question for you. With the Quickjack, which direction did you use it? I have mine with the hose pointed towards the front of the car, so when you raise it, the front of the car moves backward, and the locking arm is diagonal from upper right to lower left, looking at the drivers side. This seems logical as most of the weight is rear/middle, as opposed to a front engine car where they show it the opposite with the hoses coming out the back. I've seen pictures on here and they are the opposite of what I did. I have the 7000 model for reference. If I should turn it around I can, but it seems solid the way it is.
redpepperracing is offline   Reply With Quote
