Old 08-05-2023, 08:43 AM   #9
elgyqc
elgyqc's Avatar
This has been covered in previous battles with the SAi system. I used silicone hose made in USA and brass fittings throughout. Sure they are not OEM but silicone and brass will outlast plastic for sure.
Try to route the hose and position fittings where they are more visible/accessible and allow enough slack to make future work easier.Use robust ,reuseable clips to keep the hose off hot items and away from moving parts.
Good ideas, including to reroute the lines to make future maintenance easier.
I ended up buying this:
MECCANIXITY Silicone Tubing Hose 2mm ID 4mm OD 8ft Red High Temperature for Water Hose Air Tube
https://www.amazon.ca/dp/B09L7MW9PK?psc=1&ref=ppx_yo2ov_dt_b_product_details
When I received it I found it a bit soft so would like to test it before replacing all the lines. I will try to find a place where I can test this silicone line and where I can easily replace it if it collapses.
Grant
