Old 08-03-2023, 03:29 PM   #2
Starter986
1998 Boxster Silver/Red
Originally Posted by Voynich View Post
So.... Not the oil fill. None of the parts seem to be leaking. Pulled apart the trunk, and then checked the line coming from the trunk into the engine bay. No leaks. Took her for a drive to see if the leak would still manifest. Yep. Sat for a couple of days while I had to work. Took her for a drive again today, pulled straight into the garage to see if could see the leak when its fresh and chase it down. Annnnd.... now I have no leak.....
Yeeeeaaahhhh. So I see no note about the transmission mounts. I thought I had an oil leak. Fresh drips from one side for day. Then the drips stopped... likely because the mount had depleted itself of fluid. However... there was stil one drop on the bottom of the mount, and that was all the evidence I needed.
Thanks to Gilles forALL his help.
So... humor us. Check that mount.
1998 Porsche Boxster
