Old 08-02-2023, 03:17 PM   #1
Starter986
1998 Boxster Silver/Red
Thank you all for the recommendations.
I'm going to attempt jumping the fuel relay one more time. I've wire and connectors... and will bring some patience. I'll be listening to hear if the fuel pump buzzes. If not... maybe it's the pump. However, before I rush into replacing the pump...
I'll check the fuel pressure at the rail. Picked up a compression test kit from HF a coule/few months back... haven't used it. Will.
The fuel filter. Since I have the car up, and the panel removed... I may attempt the filter. However... I was able to remove the line with the click attachment. However, the other, exiting, line appears to slip over a fuel line... with no clamp... and appears to have been on there for some time. How the heck does that come off?
It's 90+ and humid... so I've called it a day. Friday and Saturday I'll return to it.
Thank you, again. I'll be back.
1998 Porsche Boxster
