Old 08-02-2023, 02:09 PM   #1
JFP in PA
I would start by connecting a fuel pressure test gauge to the Schrader valve test port on the fuel line and testing for both pressure and fuel deliver rates. If either is off spec, I would pull the fuel filter and replace it, then test pressure and deliver again. If it still fails, the pump itself is bad. Whenever we do a pump on one of the early 986's with and external filter, we always replace the filter along with the pump, so you would already have a new filter in place. Misfires are common when the system goes way lean.
