Old 08-02-2023, 01:04 PM   #7
The Radium King
The Radium King's Avatar
occams razor - fuel gauge issue related to no start/rough running issue.
where do the two meet - fuel pump / fuel level sending unit - one unit located under battery.
battery - two terminals and one fastener to remove.
fuel tank cover plate - four fasteners.
start with the electrical connection which should be visible once cover plate removed,
then pull the assembly (easy as per sennigen) and visually inspect for mechanical issues.
