Old 07-31-2023, 12:56 PM   #3
elgyqc
elgyqc's Avatar
Seems like there may be a crack where the "tray" section is attached to the rest of the heat exchanger. Did you apply the correct torque values?
Yes, I'm pretty careful with torquing. But there is a dent in cooler on the top rear edge, maybe it took a hit when it was removed from the donor car.
I have another cooler from the engine that was originally in the car... but it is likely contaminated with bearing flakes like those I found in the oil pan.
There is an oil cooler on Amazon for about $60 CAN with a year garantie and 30 day return. I will likely order it.
Grant
