Old 07-30-2023, 02:54 PM   #27
nuvolari
Strange. I would think those grooves get rounded after the engine running like this.
The ad is on facebook marketplace. 2004 Porsche Boxster S Motor for $200, was $500; in Marina del Rey, CA, near Venice.
Thanks, found it and asked how bad it is but no response. Pretty difficult to deal with on the other side of the country but for $200, it's worth considering.
I got a couple borescopes but, geez, these things are not easy to use! And that's with the engine out, on an engine stand and turned upside down! And I'm trying to see into cylinder #2 which is the easiest of all to get into! Then when I was able to get the camera into the cylinder, the fact that what you're trying to see is basically a half circle of shiny aluminum makes the view extremely difficult to make out due to reflections and focusing. Also, I am using a scope with the tiny 45 degree mirror on it which completely destroys the quality and adds all sorts of reflections and focusing difficulty. I think a 90 degree camera tip is needed but that adds much expense to the scope and makes it impossible to find one to borrow from an auto parts store.
So, does anyone have any tips? Of course, I'm talking about trying to use the borescope to see the bottom ends of the cylinders, going in from the sump. I don't think it's really possible to use the mirror attachment for this purpose; has anyone used this attachment successfully? The scope I bought was an Amazon $30 part and without the mirror, the quality is very good, much better than you would expect for such a low price. And you really must have a 90 degree view once inside the cylinder or all you will see is the underside of the piston.
It's a very frustrating process and I can't imagine being able to see into all the cylinders. As I've said, the middle #2 has the easiest access but the others....Well, I didn't even try as once inside #2, I really couldn't see anything. I thought saw scoring but it was too tough to tell if it was scoring, reflection or some other anomaly.
Ok, time top research more borescopes/endoscopes....
00 986S
86 944 Turbo
87 VW Scirocco 16v
87 Alfa Romeo Milano
77 Alfa Romeo Alfetta Sedan
nuvolari is offline   Reply With Quote
