My last problem before trying to start the engine was a leaking power steering return hose... the one I rebuilt, see the picture in post # 57 above, it's the hose on the left of the picture.
When I filled the reservoir it started to leak even without pressure in the system. I had used 1/2" hydraulic hose in place of 12mm and the difference was enough that even with it clamped hard it was leaking. 12mm hose is hard to come by, especially late on a Friday when dealerships that might have it are closed. So yesterday I went to Kenny U Pull and found a P/S hose on a BMW that was long enough. The installation with the engine in the car was a challenge but I got it in, with 2 clamps on each end and so far it is leak free.
Next installment... seeing if it will start...
Grant
Reason: added info
