Old 07-30-2023, 09:45 AM   #1
Luckyman01
The more I read, the less I know (Purge valves)
At one point I thought that the valve under in intake manifold was THE purge valve. However I am reading references to one under the right front fender.
I do understand the valve attached to the gas tank tube, I think.
However there seems to be something on the upper wheel well that is referred to as a valve as well.
There seems to be valves associated with both the EVAP and SAI.
Can someone give me a clear narrative.
I am chasing a does not start?
David
Luckyman01 is online now   Reply With Quote
