Old 07-27-2023, 08:41 AM   #5
blue62
The first thing to do is check related fuses to see if you have a blown fuse.
If you do have a blown fuse then it was most likely caused by a short on the circuit.
You say the instrument lights went out when you selected reverse and you also heard a soft pulsing sound coming from the center console area.
So If you have a blown fuse related to instrument lights I would be looking at the wiring under and around the center console and the shifter.
If you have a blown fuse you need to find the fault.
